Home > In Car Electronics > In op car stereo Harmon Kardon
hopeydot
England 2005 Range Rover Sport TDV6 SE Zambezi Silver
Probably been covered before , my 2005 sport 2.7 SE stereo has stopped working , lights up & volume will go up & down but just base noise nothing else !
Any ideas , things to check please ! Can it be bypassed with new head unit ??
Many thanks
Hopeydot
Post #647315 Sun Mar 16 2025 10:21pm
Are you saying you are just getting base from the tailgate sub ?
Not heard of that issue before. It could be the amp, under the drivers seat. (note the amp colour (black or silver) is important and not interchangeable
fitting an aftermarket headunit, will cause the colour display above to stop working. (unless you keep the rear half of the headunit connected (and stored in upper glovebox)
Fitting an aftermarket headunit (if you have an amp under the drivers seat), you will need to purchase a speaker extension loom, to run between the headunit and drivers seat. Usually these fetch ~£200
Post #647322 Mon Mar 17 2025 9:08am
