![]() | Home > General (L494) > Exhaust leak? |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
Parts are here: -
I don't see why not, my 2007 L320 sport is still going strong at 545k miles with its present owner. Golden rule is, never, ever take them to a main dealer! |
Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 313 ![]() |
Just an update on this had a look at injector 2 that needs the washer replacing and not a lot of space to work in! So I’ve booked in at my local garage but they can’t see me for another 2 weeks - am I okay to drive the car for short journeys until then - don’t want to cause any damage to the injector as the noise gets louder once the car is upto temp after 15/20 mins |
All I can say is I drove mine back from the south of France, near on 1000 miles will no ill effect when I came to replace the washer. Injector was a bit gunked up with the blow by gasses, but soon cleaned up to as good as new. |
Thanks dude - I’ve seen this kit on eBay https://www.ebay.co.uk/itm/176208795299?mk...media=COPY
Yep, that would do, ideally I'd get the clamp plate too. |
The injectors on the TDV6 could be tight but on the 3.0 SDV6 they usually jump pull out by hand, didn't have a problem with mine. You need to remove the coolant crossover pipe then you can remove the sound deadening and access is then easy. |
