![]() | Home > Technical > Glow Plug Measurements |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 447 ![]() ![]() ![]() |
For good winter starting on the 2.7 you need a 2.2K resistor across the temp gauge sender ..its RHS radiator hose . This is the equivalent of pouring hot water on the sensor .
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 114 ![]() ![]() ![]() |
No need for bypass as I have remote operated pre heater gizmo which i use when it's really cold, run for about 10 mins and it starts fine. Just more concerned about unburnt fuel smoke from exhaust when I don't use it.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5066 ![]() ![]() ![]() |
yeah 2 GP not working.
Yeah mate. It starts but a bit lumpy for a few seconds or so.
See last post
Below Zero deg the ECU increases fuel to the point where the engine is flooded and does not atart ...hence the hot water trick.
Arh. Good point.
