Home > General (L461) > TOPPING UP THE COOLANT
CHRISTOS PSALTIS
Cyprus
How often topping up the coolant is required ?
Does the MY2025 RRSPORT has low coolant warning lamp or indication ?
How much coolant is normal to add every 1600 km (1000 miles) ?
Thank you all for your participation.
MY 2025 RRSPORT D300 SE DYNAMIC
Post #647140 Mon Mar 03 2025 9:38am
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
I haven’t had to top mine at all in 15 months and 15000 miles (D350).
But there have been reports of others needing to top up more frequently either due to minor (almost undetectable) leaks or insufficient coolant from new (airlocks).
Post #647164 Tue Mar 04 2025 11:26pm
CHRISTOS PSALTIS
Cyprus
Good morning and many thanks.
Having a look at the iGuide for MY2025 RRSPORT D300, i see that the low coolant level warning lamp(yellow)/message has been omitted.This makes me nervous knowing that i will be
warned only when the engine temperature is too high.
Concerning the airlocks does the problem stop after 2-3 toppings?
Post #647169 Wed Mar 05 2025 9:40am
JDPRRSUK
I don’t know as it hasn’t happened to mine. I would top up and keep a close eye on it with regular checks. If you need to keep topping up something is wrong and I would go straight to dealer
Post #647183 Thu Mar 06 2025 8:00am
eggberttehgreat
I would say pretty much never.
I have just had my expansion tank and cap changed after loosing coolant as apparently there is now a known issue with them.
Post #647349 Thu Mar 20 2025 8:06pm
CHRISTOS PSALTIS
Cyprus
What MY ?
Mine the expansion tank is covered with little red powder around the middle reinforcing ring.
Is that sign of leakage?
Thank you
2025MY D300 SE Dynamic
Post #647354 Fri Mar 21 2025 9:12am
