Home > Technical > ACE ecu
Reno
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Baltic Blue
ACE ecu
2011 L320 diesel, does anyone know if the ACE ECU units are plug and play or do they need to be programmed to the car. I suspect mine is faulty and needs exchanging.
Thanks.
Post #647016 Fri Feb 21 2025 11:37am
Disco_Mikey
They can be used 2nd hand, but need the correct firmware installed Thumbs Up
Post #647021 Fri Feb 21 2025 7:59pm
Reno
Can you elaborate, my understanding was that the CCF files automatically detect the correct ECU is installed. Not sure what you mean by firmware.
Thanks
Post #647027 Sat Feb 22 2025 10:21am
Disco_Mikey
The actual firmware/software installed into the ECU. It's different for 2.7/3.6/4.2 models etc. Also different for different model years too
The CCF is completely separate from the ACE firmware
Post #647031 Sat Feb 22 2025 1:39pm
I believe the module has a choice of "tunes" available when it's made and the correct one for the vehicle is selected when it's first installed. So if you have a TDV8, for example, getting a second hand module from a TDV8 should make things easier, especially if you can find the right year.
The different tuning is because the different engines are heavier/lighter and that has an effect on roll which the system has to control. 2012 SDV6 - it's missing a couple of cylinders
Post #647051 Mon Feb 24 2025 9:48am
