![]() | Home > Technical > Dab Gremlin? |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 433 ![]() ![]() |
Green left - picture is correct |
RallyeSport Member Since: 20 Jun 2024 Location: Gloucester Posts: 107 ![]() ![]() ![]() |
Green = right/bottom
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
Hi Jonny, I've just fitted my DAB+ module this morning, all seems to be working and I can actually find more stations now than with old unit. I have noticed exactly the same as you regarding opening DAB on the screen, whereby I have to turn off the head unit and back on to access DAB. Also when turning the unit back on I don't get any volume until I move the volume knob slightly, but only on DAB, everything else is fine and audio can be heard without adjusting the volume. Hopefully someone will come up with a fix but otherwise it's fine. Many thanks Craig 2010 RRS 3.6 TDV8 HSE Galway Green |
I've just been out to the RRS and setup the bass, treble etc as they were reset when disconnecting the battery and carrying out a hard reset requested by Patrick from GAP (different issue)
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 253 ![]() ![]() ![]() |
Not heard the subwoofer but when i turn ignition off, The home screen goes off but Dab radio and sound stays on for a couple of minutes and then goes off, Or dab goes off as soon as you lock the doors. It seems its a syncing issue. |
I wonder if that's what's happening with mine then as I had not tried to lock and then unlock to check 2010 RRS 3.6 TDV8 HSE Galway Green |
I would guess so, It seems they’re all behaving the same after replacing either the dab module or upgrading to dab + its the same symptoms so some sort of coding/reset must be required so everything syncs up as it did before. |
Hello,
I will have a read on disco forum they have alot of active members i find, Its definitely still worth doing if your dab is goosed like mine was because even a like for like swap has this issue as i found out. Will update if i find anything out. |
I’ve had a look on the L322 forums the best I can, loads of people suffer the same consequences as we all have, these are posts going back to 2022.
Id contacted Patrick at GAP, who has said that the behaviors from the L405 DAB module cannot be corrected, he is surprised that the module works at all because Land Rover updated the complete entertainment system.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5148 ![]() ![]() ![]() |
As I said earlier L/R do or did a upgrade kit to DAB+ (LR079560) which consists of the module CPLA-14F720 (LR079410) and wiring adapter/plug LR032814 or Jag part no. C2D22599. However this is only listed for Vin No. CA000001 on which I think will be vehicles with the later updated entertainment interface, which might explain why some are having a issue with getting it working correctly.
There you go then Col.
Would think there would certainly be some wiring modifications needed at least even if it is possible, as the connections on the rear of the Bosch screen are certainly different to the Denso one. Would probably need the later IAM unit as well.
