![]() | Home > Technical > Dab Gremlin? |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 433 ![]() ![]() |
Nope - will have a go at the weekend hopefully. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5148 ![]() ![]() ![]() |
There are some DAB settings in the CCF files, I can't actually remember what they are though, only that as they don't actually have DAB radio here only in a few cities, I did turn mine off in the ccf files, so there may be some setting in the CCF that you may need to configure when upgrading, as I say I don't know for sure only a suggestion but might be worth a look.
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 253 ![]() ![]() ![]() |
Thanks for that Col, I do think its more connected to ccf files, I can manage it until someone has a definitive answer, It works i get talk radio and heart 90’s now that will do me 😃 |
Not sure if this is of any relevance or not if upgrading.
RallyeSport Member Since: 20 Jun 2024 Location: Gloucester Posts: 107 ![]() ![]() ![]() |
Hello,
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
I've just received my connector kit. They've written on the connector for which wire goes where.
My connector has been wired up exactly like that. It could be a little confusing working out what wire goes left and right, depending on which way up the connector block is, but I had no issues and the pictures were very clear. |
That's great, thanks Jonny.
Just re-checked my pics and that appears to be the wrong way round ! I think you may have a stray connector there. I'll re-check mine a little later, as I need to replace some clips. |
Thanks Jonny and thanks for your message
Looks wrong to me aswell, Double check. |
The seller I bought mine from was ‘crap jokes’.
Hi Dean,
So….
