![]() | Home > General (L461) > WIRELESS CHARGING PLATE |
Tizzy Member Since: 30 Dec 2023 Location: Leicestershire Posts: 36 ![]() ![]() |
Mine seems to work fine with an iPhone 14, gets quite hot though and the charge rate is pretty slow |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 569 ![]() ![]() |
FunkGogh Member Since: 02 Oct 2024 Location: inside MacBook Pro Posts: 14 ![]() ![]() |
HI
Meshan Member Since: 19 Oct 2024 Location: Northampton Posts: 85 ![]() ![]() ![]() |
There are also different standards for charging
maurizio_italia Member Since: 04 Feb 2025 Location: Torino Posts: 4 ![]() ![]() |
Hi, I use an iphone 14 max and specific cover for the wireless charge "mag safe", I also tried to remove it. I have to make several attempts before the power-up tells me it is active, it never works just by leaning on it. Nothing serious but sometimes it is turned on and off continuously and this is not good for the phone battery. I will report it at the first check. |
jorosa Member Since: 01 Dec 2012 Location: Lincolnshire Posts: 30 ![]() ![]() |
My phone also cuts in and out of charging, this did get better with one of the PIVI PRO updates, but the worst thing is the heat it generates as on my 1.5hr commute the phone shuts down as it has got too hot!
