![]() | Home > General > Heated steering wheel upgrade. Update, it works. |
LesW Member Since: 30 Oct 2021 Location: Pays de la Loire Posts: 85 ![]() ![]() |
I have ordered the clockspring today, so that's one thing off the list.
Update.
I just took it for a spin and the paddles don't work. The heat is really fast and very good though. A Cheshire expat in France.
phazed Member Since: 02 Feb 2025 Location: Dorking Posts: 12 ![]() ![]() ![]() |
That is good to know that this modification can be done.
Just as a starter. The first thing I did was to check the owners handbook to see which fuse supplied the heated steering wheel. If the fuse is there, then I assume the wiring will be too, just like mine was.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5085 ![]() ![]() ![]() |
Yes it can be done as I did it on my old 09 plate pre-facelift car, but you would need the heated steering wheel, switch packs and clockspring from a facelift L320 or a later Disco 4 if I remember right.
Thanks for that. A project for the future. First I need to sort out what this low whine is that has started coming from I think is the front of the car. |
