![]() | Home > Technical > Dab Gremlin? |
| JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 433
Welcome - let us know how you get on ! |
| RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 112
Jonny,
Hi Dean PM says the same as your post on this thread.
I’m in the process of buying the said DAB+ module, would you mind talking me through a couple of questions I have. Would you be willing for me to contact you for a quick chat, if so pm me your details, not sure why my PM can’t be read? |
| Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231
Sorry, silly question, do you need to change the antenna after changing to the DAB+ module.
I used the existing antenna |
That's great, thanks Jonny
Only one minor glitch I’ve noticed is that when switching from normal radio to DAB, which I don’t do very often, the DAB doesn’t come straight on. You need to press the DAB button then switch the radio off and on again. DAB is then automatically selected.
Thanks for the update Jonny.
| jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 253
Im Same Jabba, Should have been delivered yesterday but Evri driver failed to deliver it. |
What DAB module did you get originally Jase ? Reading back on the thread it seems that your original issue is what I have. I think it’s just a config file or something and not an issue for me, as it takes 2 seconds to turn the audio off and on again.
Yes it seems that could be case, My original just stopped working so i replaced it with another dab unit old style which has the gremlins, Have to turn dial on and off after i select dab or it worked select it, Then its selected you have to adjust volume for sound to work, So i could manage that but might aswell upgrade to dab+ and hopefully it all works which i will report back once this connecter turns up today. I think a hard reset negative to positive on battery connections might work for the gremlin if its all confused, Another thing is dab stays on when engine is off and turned off until you lock car so a few things going off. |
My replacement is DAB+ and I have exactly the same as you, so it seems that the quirk applies to any DAB module that gets changed over, irrespective of whether it’s DAB or DAB+.
Right, So your dab+ upgrade is not operating correctly? Have you tried a hard reset of the power, terminals off battery and bridge together which drains all power out of ecu’s etc ? Thats what i will do if my new dab+ is the same. |
| All times are GMT |
