![]() | Home > General > New SVR owner best security |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586 ![]() ![]() |
SVRSVR Member Since: 25 Jan 2025 Location: London Posts: 11 ![]() ![]() |
Thanks for the reply, will check it out. Tracker needed? From memory with the BMW's, tracker was pretty pointless as once its gone its gone and they will disable the tracker anyway. Maybe a couple air tags plotted around the car? |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 934 ![]() ![]() |
When at home put your keys in a metal container. Mine are in an old coffee/tea container. Stops relay theft. Try it by taking the container with keys in it up to the car & check the doors will not open |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 554 ![]() |
Am hearing the baddies have already cracked the new code … the fitting of a Ghost is essential… again ensure the fitter configures it as Scrumps says via the gearbox. This will still enable the remote warm up and also protect the car as they were hacking in via the remote start.. By going down the gearbox lock route means they won’t be able to drive it away even if they get the engine running! Don’t bother with the JLR tracker as they can instantly delete it.. … instead buy a Cantrack battery tracker which without doubt are the best tracker you can buy! |
