Home > Technical > Adaptive Dynamic Fault
DuncThe Geek
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Zermatt Silver
Hi All
Working my way through the glitches with my new (2011) RRS 3.0 Diesel. Seems the previous owner didn't like replacing blown bulbs but all sorted now.
Anyway, I have the Adaptive Dynamics yellow triangle up, attempting to select any AD modes on the rotary dial says that they're disabled.
Checked the ODBC port with my generic reader and nothing coming up.
So given that there's no codes, what are the starters for 10 as to the likely culprits?
Cheers - Dunc.
(This may well have been answered as I'm slowly trawling through past posts but certainly won't be my last stupid question!)
Post #646190 Thu Jan 09 2025 3:56pm
bmszabo
Netherlands 2013 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Humm.. Had a similar problem with my 2014 RRS; my (very good!) indy service guy has changed nearly everything possibly related items on the car suspension, without result; finally it turned out to be a broken wire (don't ask me where) to be the culprit.
Just my 2, before replacing a lot of (expensive) items double-check the wiring.
Post #646196 Thu Jan 09 2025 10:44pm
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
A "generic reader" likely only reads the engine ECU, have the codes read by a proper scanner. 2009 Range Rover Sport Supercharged
Post #646214 Fri Jan 10 2025 8:18pm
JonnyCJ
Hi Dunc - if you don't already know them, try Bell Automotive in Queensferry. They're a lot easier to book an appointment with than Ian Barclay in Birkenhead.
Post #646282 Mon Jan 13 2025 5:16pm
Ian335
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
I had a similar problem with my 2011 3.0 diesel last July. Landrangerdeeside in North Wales diagnosed a faulty rear height sensor. They fitted a new one together with a new Propshaft which was falling to pieces.Car fine now. I would recommend. Regards Ian.
Post #646295 Tue Jan 14 2025 4:02am
DuncThe Geek
Thanks for that, good to know both those names.
It's with my local back street guy that I've known for years for a cambelt and I'm hoping his kit will say which one it is. They do seem to be prone to the wiring going open circuit so fingers crossed for an easy fix on that. SEO Geek, Writer & Photographer by day.
Too tired to be Batman by night.
Allergic to cats, horses, traffic wardens & speed cameras.
I have a teenage daughter and a Range Rover Sport - that's why I never have enough money for beer or pizza!
Post #646374 Sun Jan 19 2025 11:34am
