Compressor dead
How do I check if my amk compressor is dead I have suspension fault after 15 seconds of start up I stupidly deflated all with gap iid tool. And it's now on bump stops I attached 12volt to power supply and it does nothing not even a click is there a better way to check compressor
Sat Dec 28 2024 4:32pm
Karlp606
Check under the boot carpet, take the spare wheel out and inspect the compressor - could be a fuse also.
If it is dead you can get a replacement on ebay for £120 and its a easy DIY job to swap it out.
Mon Dec 30 2024 1:05pm
Gerryd
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
