Home > Maintenance & Modifications > Normal Ride height with Codes
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
Good evening all,
Been searching around but have yet to nail the issue down.
So its a 2013 L320 HSE Black 77000 miles.
Very intermittently getting the "Normal Height Only" yellow triangle warning. No Rhyme nor reason as to when it's coming on. could be once a week to twice a day, and clears its self when ignition turned off or just while driving along.
All ride heights are available with ignition on.
Searching brings many possibilities, however I wanted to throw it out there to see if we can narrow options down, codes below.
Thanks in advance
CJS
Post #645911 Thu Dec 26 2024 7:33pm
Any help? I believe a blocked intake filter/silencer has been mentioned on a few post previously.
Post #645912 Thu Dec 26 2024 9:32pm
Cpt Jack Sparrow
Cheers Col
hopefully its that simple, and pretty straightforward to fix.
CJS Thumbs Up Thumbs Up
Post #645913 Thu Dec 26 2024 9:48pm
Forgot to add this one for the first code.
Post #645917 Thu Dec 26 2024 10:21pm
Cpt Jack Sparrow
I guess that filter is behind the rear light cluster
CJS
Post #645918 Thu Dec 26 2024 10:36pm
I think it is behind the n/s load space trim, not the rear lamp, but not totally sure. I think a new L/R one is complete with the pipe so you might need a push fit joiner to splice it in to save removing the whole pipe/filter assy. thing.
If you want the whole L/R procedure. Rolling with laughter
https://drive.google.com/file/d/1Xmkdvv4xO...sp=sharing
Post #645920 Thu Dec 26 2024 10:58pm
Cpt Jack Sparrow
Once again Thanks Col
Much appreciated as always
Have a great new year
CJS Chawton White
Post #645926 Fri Dec 27 2024 7:26am
Karlp606
Had the same issue on my L494 - Compressor was on the way out - just swapped with another on ebay and all okay now.
Post #645928 Fri Dec 27 2024 12:14pm
