Home > My Range Rover Sport > L320 - wheel arch removal - corroded screws
jig
2011 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Hi All,
Apreciate any help/advice on getting the front drivers side wheel arch liner off, unfortunately the fron screws underneath are corroded and i cant seem to turn them at all. I have ruined the heads on both and though i could try and cut them but no luck. I have attached pics from underneath and inside. I am hoping i can not ruin the arch as want to re-join without having to purchase another! Help!!
Thanks in advance
Post #645773 Sat Dec 14 2024 5:33pm
Meshan
I pulled the heads on the off, on screws holding my wheel arches on.
Used WD40, and these.
https://www.amazon.co.uk/extractor-grippin...6HJAA?th=1 L320 Range Rover Sport 2008
3.6 TDV8
Post #645774 Sat Dec 14 2024 5:40pm
jig
so heads off then turn with pliers? thanks[/quote]
Post #645775 Sat Dec 14 2024 6:01pm
gogsy1956
Use a pair of mole grips,,, great bit of kit for jobs like that,, you will be able to lock them on, once you get a bit movement the jobs almost done 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #645777 Sat Dec 14 2024 8:15pm
Use stainless steel screws and a bit of copperslip grease when replacing them. When I had nothing better to do I replaced a lot of the screws on mine with stainless makes it so much easier if you do need to remove them.
Post #645787 Sat Dec 14 2024 10:44pm
jig
Thanks mole grips failing to get a bit of the screw ;(
Post #645800 Sun Dec 15 2024 4:01pm
jig
Thanks col noted and will do but still struggling to remove really don't want to destroy the wheel arch.
Post #645801 Sun Dec 15 2024 4:02pm
jig
i lost the plot and attacked this with the dremmel to remove the head but failed looks bad Sad
Post #645802 Sun Dec 15 2024 4:59pm
