![]() | Home > Maintenance & Modifications > What a total |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5121 ![]() ![]() ![]() |
yeah, its nasty if the fan hasn't been off in a white
Axl Member Since: 20 Nov 2024 Location: Ayr Posts: 73 ![]() ![]() |
Can't do that as there's more pipes in front of it, also don't have a 38mil.
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 433 ![]() ![]() |
I reckon £300 at a garage. What do you want for the car ?
I think you’re missing the point. I’m trying to be helpful and saying that you’re not doing yourself a favour by scrapping the car when you can fix it for £300 or so.
Nobody wants to do it apart from one and they're busy till Feb
Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231 ![]() ![]() ![]() |
Hi, I've been reading a lot lately regarding changing an alternator on a rrs tdv8.
Thanks for the link yes I've read that before, it's mainly me, I'm just not in the right frame of mind and don't have the right tools. |
Yes, it's does make a big difference. The trouble is the older we get, the more we can't be asked.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 959 ![]() ![]() ![]() |
Did mine last year,, maybe I was lucky but the fan came off quite easily, didn't use any special tools,, I know I used a 12" pipe wrench and can't remember what else. Hardest part was getting the 2 bottom bolts back in,, I found that taking off the bottom intercooler hose then pulling the pipe down and tying off gives another 15mm clearance to play with,,, makes a huge difference. It is awkward but a little perseverance will get it sorted. 2010 RRS, TDV8
Yes I'm finding I can't be bothered doing a lot of stuff now even simple things, I've got to push myself. It's mainly because now I've no garage to hide in. |
I managed to get the right spanner for it ie 32/36mm and got the fan loosened. This is a love hate with this bloody car. Yes these bottom bolts were a bad I managed to move the metal and rubber pipe just a smidge out the way, so bad though. I've still not got it fitted yet though between work and looking after a mother with the start of either dementia or alzheimers hence not in the right frame of mind plus working outside. |
Hi Axl - hope you had a relaxing Christmas given all that's going on for you.
Hi Jonny
