Home > General > Back in a RRS after 6 years
JonnyCJ
More details please !
Cost, ease of installation, does it access data through your phone etc etc
My 11 yr old would love to get his sticky fingers on it.
Jonny
Post #645400 Fri Nov 22 2024 7:41pm
CarbonTrac wrote:
Looks lovely Col! What bumpers are these? I really like the DRLs (assuming thats what they are?).
Thanks
Yeah, they are DRL's the bumpers are from a overfinch GTS bodykit.
Post #645402 Fri Nov 22 2024 9:34pm
CarbonTrac
Jonny
Hi Jonny,
Fairly simple install to be honest, you've just got to be confident with pulling your dash apart. Only 10 screws in total have to be removed though, everything else is on clips. I had some advice from Col for mounting the actual box itself which was useful (thanks Col).
Overall, and for the price, I'm chuffed with the results. I had read a few reviews on the unit going into it so I knew wireless CarPlay was a bit hit and miss (which it is) but that doesn't bother me as I prefer a wired connection to keep my phone charged. It supports CarPlay, Android Auto, Screen Mirroring and some other bits but for me I just wanted Google Maps and Spotify via CarPlay.
I got the unit from AliExpress (https://www.aliexpress.com/item/1005004770255674.html) but after receiving it I found it was from a firm called CARABC. If you look on the CARABC website its available as well, slightly more in terms of cost but you may get better after care (should you need it) buying from the manufacturer direct.
Happy to answer any other questions, I've included a few photos below which may, or may not, be useful.
Thanks
Post #645405 Sat Nov 23 2024 10:18am
JonnyCJ
Really helpful - many thanks.
Will do some investigating. I also prefer hard wiring as Bluetooth sound quality is bobbins.
Jonny
Post #645406 Sat Nov 23 2024 10:26am
JonnyCJ
Just following up - it looks like the existing screen is used and it’s just the box of electronics that’s supplied ?
Can’t quite tell from your pic, but it looks like the unit is mounted somewhere near the armrest ?
Post #645407 Sat Nov 23 2024 11:15am
CarbonTrac
Yes - the existing screen is utilised and you still have access to the original menus as well. Basically this box (I believe all options do the same as well) sits inline of the Nav input so you will lose factory sat nav, when you press the Nav button, CarPlay / Android Auto launches. If you want to come back to the standard RR menus you just press the Home button. It's pretty slick to be honest, and I havent used my factory nav once since owning the car so I'm not missing a lot.
In terms of installation, I have added a Blue line where mine has been nicely tucked away, it sits under a plastic support bar and I just used double sided sticky pads (to reduced any potential vibration) and cable ties. I know some owners choose to put it behind the glove box but I found it to be too tight here.
I hope it helps.
James
Post #645408 Sat Nov 23 2024 11:29am
JonnyCJ
Many thanks James
Post #645409 Sat Nov 23 2024 11:39am
JonnyCJ
Think I may be scuppered at the first hurdle. My car is a 2011 and pretty sure it has the Denso head unit. I’ve emailed Carabc and will see if they do a unit, as I think you and Col have Bosch head units.
Post #645410 Sat Nov 23 2024 11:51am
T
England 2012 Range Rover Sport SDV6 HSE Santorini Black
Thanks for posting details and pics of this James, I've just ordered one for myself. Thumbs Up
I've been tempted for a while, but I'm disabled and have very limited use of my left hand so haven't bothered. However, given the cheap price of the unit I think I may be able to borrow one of my grandson's hands to help. Wink
Post #645411 Sat Nov 23 2024 12:34pm
RallyeSport
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Stornoway Grey
That looks a very similar colour to Stornoway Grey.
I have a Autobiography Sport TDV8 in Stornoway Grey.
Lovely spec, I'm guessing yours will have the raise up gear selector?
Cheers Dean
Post #645526 Thu Nov 28 2024 7:58pm
JonnyCJ
Stornoway Grey is a very classy colour
Post #645528 Thu Nov 28 2024 8:29pm
