![]() | Home > General > Normal Ride Height Only Message |
Fault codes first |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167
Eh up Disco Mikey
| gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961
I have had the same issue for a while now,, sometimes it's fine for days on end, then I might get the fault a couple of times in a day. Some time ago I rebuilt the compressor as was having other issues and all was fine for a good while then this issue surfaced. I was in the process of running a few tests,,, but life took over and it's been on the back burner of late. What I did find out when I was fiddling one day, was that the compressor had started as it should have, but cut out after a few seconds. I quickly removed the main connector from the compressor and checked for a supply,, and I was getting more than 12V,, but the compressor was not running. I think I am correct in assuming the main two pin connection is the supply to drive the compressor,, if it is live compressor should run?. Compressor motor wa quite warm at this time which leads me to think it is the motor itself at fault. These are permanent magnet motors and are not serviceable so in short the overall problem is the compressor unit,, but the item at fault is the motor,,.
| Karlp606 Member Since: 25 Jun 2022 Location: East Yorks Posts: 322 |
Compressor on its way out, same thing happend to me.
Eh up gogsy1956
Hi yes have a look on eBay for a replacement compressor any for a l494 will be fine - compressor is located under the spare wheel in the boot, easy to swap out disconnect everything reconnect should be all good.
Eh up Karlp606
Is yours a l494 or a l320?
Eh up
Check here matey , looks fairly straight forward
Eh up Karlp606
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5142
I don’t think it will deflate from memory. But you need to take safe precautions anyway
Eh up Andy K
Front valve block is easier.
| All times are GMT |
