![]() | Home > General (L494) > P400e Timed Charging |
midlife Member Since: 24 Apr 2022 Location: Cork Posts: 7 ![]() ![]() |
Departure and charging times are controlled by the User interface in car. If you are using granny charger you may not have enough time to charge fully as I think if I remember you are lucky to get 2.3 kwh in an hour. A single phase 32 amp charger takes just over 2 hours from empty to full and I use a zappi on ev rate for 3 hours.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 933 ![]() ![]() |
Used the user interface, get the message that charging will start at midnight as programmed when i switch off the car, but as soon as I plug in the charger it immediately begins charging?????
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1921 ![]() ![]() |
How are you setting it up, via the app or in the car?
Using the in car screen. Daft question, where is the app
Those are totally different pages to my Sport, but it looks like you have a departure time of 00:05?
Ok, thanks, will give it a go |
jimbg
No problem. When I got my P400e 3 years ago I did exactly the same and did not realise the significance of the departure time.
