![]() | Home > Maintenance & Modifications > osr door wont open |
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
Sounds as if there is a problem with the small motor that operates the deadlock. How is the voltage on your battery? I saw your other post about intermittent loss of the rear camera and wondered if it might be related to low volts.
| adameverett Member Since: 14 Nov 2015 Location: Warwick Posts: 110
I thought I would post an update on my door lock issue. I spoke with the guy from LR trade parts http://lrtradeparts.co.uk/ and explained the lock had failed 2 weeks in after fitting. Apparently when they do fail they can get jammed and the only way is to brute force destruction to get them removed |
| NeilRRS Member Since: 18 Aug 2016 Location: Stone, Staffs. Posts: 36
Old post but still useful as my new lock also locked me out and I had to conduct the above to get in again... |
| Adrian C Member Since: 07 Nov 2024 Location: Hampshire Posts: 1
This is brilliant advice, and just what I have been looking for. Every other bit of advice has been to press the lock/unlock buttons repeatedly and hope for the best. I've just bought a 2007 RRS and the lock has never worked or even made the slightest of noises. I was fearing that I would have to damage my RRS in some way just to get the door to open and then have to live with the battle scares forever more!!! So fingers crossed this works for me tomorrow. |
| Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 428
I never use superlock on my TDV8 just in case the door lock fails and I cannot open the car from the inside. I figure after 14 years one of the locks is about to bound to fail. |
| JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 435
One easy fix that can outsmart even the smartest of operators, is the door pin that pops up in the door card to show whether the door is locked or not.
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
Don't recall the sport having the pop-up type button, is the button not part of the internal release handle assy. Have had one rear door lock/actuator fail but was initially intermittent so changed it before it failed completely with the door locked.
Good point Col - my experience of this happening was on an L322. |
| All times are GMT |
