Home > Faults & Fixes > No heat from the passenger side air vents 2008 TDV8
Alfie
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
Hi everyone, so I have heat from drivers side air vents but only mild / cool air from passenger side vents??be grateful of any suggestions/ help on this please
Post #645144 Fri Nov 08 2024 5:25pm
Heater matrix gets blocked.
Not very easy to unblock so a replacement nissens unit is fitted.
Not too bad a job if the factory pipes have a join in the drivers footwell.
Dash out job if no join!
Post #645145 Fri Nov 08 2024 6:26pm
Alfie
Thanks for the reply, will investigate, are these expensive items to replace?
Post #645151 Fri Nov 08 2024 10:45pm
Alfie
The Nissen replacement unit for the TDV8 3.6 is £80 , time to investigate if its doable 🫣 I have found videos on YouTube explaining how to flush the matrix using radiator flush solution but by the time I’ve invested in the 3/4 inch pipes and a small electric pump etc fitting the replacement nissen unit would be the better option. Fingers crossed I’m able to, thanks for pointing me in the right direction
Post #645153 Sat Nov 09 2024 9:03am
