![]() | Home > Maintenance & Modifications > Range rover l322 4.2 supercharged engine swap into a l320?! |
Zixt Member Since: 10 Jul 2024 Location: London Posts: 5 ![]() ![]() ![]() |
Hi Scott
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5106 ![]() ![]() ![]() |
At a guess accessories like the suspension pump and mounting and air con compressor etc. will be different. and wiring loom etc
So... we ended up doing it!
Engine swap Member Since: 04 Dec 2024 Location: Rockhampton Posts: 1 ![]() ![]() |
Hey mate I'm currently swapping engines, I have two 4.2 supercharged engines both out of 2006 range rover sports. the one I'm removing is no good do you think I can put the good engine in without any problems any information would be greatly appreciated cheers for australia |
If it's the same engine and same type donor vehicle can't imagine you'd have a problem. |
