Home > Faults & Fixes > L320 Suspension compressor**SOLVED**
which option?
new AMK compressor
25%
 25%  [1]
hitachi refurb kit
50%
 50%  [2]
new hitachi compressor
25%
 25%  [1]
Total Votes: 4
jpvd
Hi All....i know this topic has been talked to death, but my hitachi compressor is dying - turns on when i fire up, runs for 15 seconds and then stops and orange light of doom appears saying standard height only and wont go up or down....mechanic plugged in the reader and it points to compressor....
so they have recommended i swap it out for the AMK one (did not recommend hitachi as they are hard to get hold off and AMK is a better unit). Its a britpart supply unit, so not a copy and around £600, plus the couple of hours labour for fitting and reprogramming ecu....
how many on here have swapped to AMK and was it an improvement and worth doing?
have considered the refurb kit, but dont want to waste time and money....
cheers! Thumbs Up
Post #645003 Thu Oct 31 2024 7:32pm
T
England 2012 Range Rover Sport SDV6 HSE Santorini Black
I have the same issue on my 2012 model, although luckily ATM it's holding in the normal position.
I don't know what's fitted, but the garage said it's a copy.
I've just checked Ebay and I see they have both Hitachi and AMK for around the £150.00 mark:
https://www.ebay.co.uk/sch/i.html?_from=R4...p;_sacat=0
This is much better than the telephone numbers the garage were quoting, but I'm completely confused - and fed up with being ripped off.
Post #645028 Fri Nov 01 2024 4:14pm
gogsy1956
The cheap ones on eBay aren't genuine Hitachi, they are lookalikes,, if you read through the description they are branded as susfat or something similar and have a very limited lifespan in most cases I think. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #645035 Fri Nov 01 2024 9:04pm
Boxers
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
I had one fitted in April ( AMK ) my indi will not use any others, just checked the invoice the compressor was £395.25 labour reprogramming etc £127.50 ( 1.5 hrs labour) VAT £104.55 total £627.30. Two years guarantee on the compressor.
Post #645037 Fri Nov 01 2024 9:34pm
jpvd
Well think my choices are either:
Buy an eBay pump and fitting kit and spend around £200 and fit myself and keep my fingers crossed
Or
Go for a genuine AMK pump and have it fitted by garage and spend £800 roughly
Looking to swap out the air tank at the same time too which is about £200 for a genuine one...
So do i go cheap and take the risk of buy cheap, buy twice...🤷🤦 Or go for updated compressor and higher cost?
Post #645039 Fri Nov 01 2024 10:55pm
garrycol
Australia
The AMk is not better to the Hitachi - it is an alternative. Rebuild your Hitachi. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #645044 Sat Nov 02 2024 9:07am
T
gogsy1956 wrote:
The cheap ones on eBay aren't genuine Hitachi, they are lookalikes.
Thanks for that, I'd better give those a miss then. Whistle
It looks like I'll be stuck in normal height for a while longer then. My PB wouldn't release yesterday, so that's another job lined up too. That's not to mention front lower bushes and ARB bushes that need replacing.
It only just cost me an arm and a kidney for the cam-belt. Big Cry
Why did I buy another bloody Range Rover? I should have listened to myself the last time . . .
Post #645047 Sat Nov 02 2024 10:58am
jpvd
i would - but i have the feeling it has completely died and not worth fixing - it doesnt even turn on anymore and before this was rattling, so it maybe past saving....the AMK kit is cheaper from britpart and upon reading reviews runs differently to the hitachi and is supposed to be more reliable and better for the system, but the only pain is i cant fit it since it will require the ecu updating....so will cost me more to have installed....dammit...i usually do all my own jobs (just replaced a whole suspension on a bmw z4 this summer - which is a 2003 and was a nightmare of snapped bolts and rustd parts) so i know there will be rusted bolts and probably snapped bolts to deal with and i dont know if i can be arsed right now!.. Laughing Laughing
..might just bit the bullet and get take her to garage and let them sort it, install the AMK and new air tank too....then its job done!
Post #645048 Sat Nov 02 2024 11:07am
jpvd
one quick question - sicne the compressor is not working, do i need to remove the fsue which controls the self levelling just to make sure it doesnt drop the suspension for any reason and then cant go back up?....if so which fuse(s) should i be pulling?
will be taking her to the garage next week hopefully, so wonr be driving until then and usually she self levels at night.....
cheers!
Post #645059 Sat Nov 02 2024 4:43pm
