![]() | Home > General (L494) > Error Messages - water in fuel..bonnet open…etc |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 593 ![]() ![]() |
Will be the earth straps, i think drivers side one shows those faults from memory |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 207 ![]() ![]() ![]() |
Passenger side under front arch liner earth stud corroded. Drivers side gives ABS and associated faults. Simple check, see which Headlight isn't working and that's your side to look at. I'd recommend doing both sides as sooner or later you'll be doing the job again! |
Baka06 Member Since: 18 Jul 2023 Location: Ipswich Posts: 1 ![]() ![]() |
I've just had the exact same issues. It was all resolved with the earth strap fix. ![]() |
