Home > General (L494) > LR034643 Top Radiator Hose
Mac35
Scotland
Noticed my coolant level dropping slowly so pressure tested the system. Very obvious leak from where the top radiator hose connects to the thermostat housing. Found the part online LR034643 for £21. So tried to order from Scuderia parts, non stock item. As soon as I went to check out it said it’s a restricted item and can’t be ordered online. Someone will be in touch to speak about options. So gave my local dealer a call to see what the story is. In their quest for money LR now sell that hose in its three sections individually. The section I need is now £192 alone. Surely that’s a p&£s take?
Has anyone bought coolant hoses lately? Any luck finding one at a reasonable price?
Post #644886 Thu Oct 24 2024 10:31am
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
For the 4.4 SDV8 the part no. is LR034643 to vin no. VINGA566160, then supercededs to part no.
LR080119 for vin no. VINGA566161 onwards.
LR online parts catalogue is showing the early one at £26.29 (but no longer available) and the latter no. at £59.26. Maltings 4x4 are showing availability of the latter no. at £49.89 at the following link :-
https://maltings4x4store.co.uk/coolant-hos...-lr080119/
Maybe worth giving Maltings a call to ensure compatability with your vehicle.
Hope this helps!!
Post #644887 Thu Oct 24 2024 11:33am
Mac35
Scotland
One of the guys from Scuderia has got back to me. He had said LR no longer supply the part, he has also said, like you say, that LR080119 superseded LR034643. He has listed all there hoses, so assume LR advise replacing all 3 at once. I guess it makes sense, if one o ring has started to leak I guess the rest won’t be far behind.
Phoned LR back and there was a mix up in the first place. He thought I was talking about the lower radiator hose (LR080120), which is indeed £193. So asked him just to order the upper hose (LR080119)as well, as it likely won’t be long till it’s starts to weep also.
Post #644890 Thu Oct 24 2024 2:31pm
NoExpert
I already feel for you…
It’s a three hose set, 118, 119 and 120 and they require a new thermostat/housing and coolant outlet. They changed the hose sizes so they’re not interchangeable. I’ve already done this exact job on several cars, it’s a pain and not cheap. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #644892 Thu Oct 24 2024 3:22pm
Mac35
Scotland
Thanks for the heads up. Unfortunately the dealership never mentioned that part. I assume that’s why Scuderia parts listed all 3 hoses. Do you know if the rear hoses that go to the oil cooler etc the same?
Ah well, the joys of Range Rover ownership.
Post #644893 Thu Oct 24 2024 4:26pm
andygts
which bit do you actually need? do you have a pic?
I had an issue with that hose on my old L405, I had to buy the new modded / superceded hose and removed the actual bit I needed, pretty sure the rest is in the bottom of a box in the garage. Current
2017 Range Rover Sport SVR
2011 Range Rover Evoque
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #644897 Thu Oct 24 2024 6:48pm
Mac35
Scotland
It appears to be o ring on the end nearest the thermostat housing of part 8260A that is leaking. Not sure if other people are able to click on the picture I added, so it’s the hose to the right of the radiator in the picture.
Post #644898 Thu Oct 24 2024 6:57pm
andygts
This may help
https://www.fullfatrr.com/forum/topic66813.html Current
Previous
Post #644899 Thu Oct 24 2024 7:20pm
Mac35
Scotland
Magic, I was hoping there would be o rings available. Bought some from simply bearings after referencing a thread for the oil cooler gasket job. Much appreciated!
Post #644901 Thu Oct 24 2024 8:25pm
Mac35
Scotland
O rings arrived yesterday. I bought the 4mm x 45mm. They were a bit too tight when trying to push the hose back on, even with a good bit of silicon grease applied. So used my Dremel to lightly buff the ID of them. Tried again and there was a decent bit of resistance but they slipped on with some medium force. I should probably went for the 3.5mm x 45mm instead. Anyway it cost me around £20 in parts instead of the best part of £600 and o have a good few spare incase it develops anymore weeps.
Post #644922 Sun Oct 27 2024 2:15pm
evautos
How do you deal with the extra two hoses coming from the modified pipes please?
There is an extra one on the top hose and an extra one on the reservoir ro thermostat hose.
We have replaced a few thermostat housings and not replaced the hoses, but apparently the hose sizes are different? I can't see anywhere for the extra two hoses to fit in any online images of the thermostat housing or remember there being an extra fittings on ones we've replaced.
Our franchised dealer has had two enquiries for the top hose this week and doesn't know how they are supposed to fit.
I expect that we will fit a new "O" ring instead ( which I think we've done previously).
Regards, Andrew
Post #647675 Mon Apr 14 2025 4:17pm
