Home > General (L494) > Upgrading to either 12.3" or 13.3" screen
Purvesh
I've currently got a 2017 Sport with the 10.5" screen at the moment with the curved bottom corners. I've bought the non CD updated AC panel for the lower section and now looking at the options for the main screen itself.
I've noticed the two sizes above and see the 12.3 is the maximum OEM style look and the 13.3 over hangs and blocks both top vents and a portion of the top of the new AC buttons. In some pictures it does and doesn't so much but there's no adjustment on the screens.
I like airflow onto my face so with the 13 blocking I'm leaning to the oem. Aside from this any other differences, many people upgraded? I noticed many people saying need to wire into oem GPS wire etc but could see many complete DIY for the L494, I have the Harman style.
Thanks for your input guys!
Post #644862 Wed Oct 23 2024 10:05am
Davenport
Hi Purvesh have you got photos of the 12.3?
All I’ve seen are 13’s which I’ve been looking at for a while, weighing up OEM size, inset larger or the full Tesla style. As with TV’s decided bigger is better but currently won’t be changing the AC panel. I’ve got the turned steel effect console which I like, much like the steering wheel buttons I’m not going to facelift.
In terms of obscuring the vents I’ll attach a shot where you can see they’re ‘only’ partially obscured, mine don’t provide any large amount to my face at regular non hectic fan speeds, wearing contacts it isn’t desirable straight into the eyes anyway. Looks like you’d get plenty of blow by to still be effective and the benefits of the larger screen for navigation (often find on the oem it’s rather squashed with split screen maps) or streaming video on the occasions I’m loitering in the car. Looks fairly OEM to my eyes not desirable to have to it all floating but that’s JLR’s offering, finessing that screen into the dash would need a total dash and centre console re-design so you can see why they’ve done it
Post #644904 Fri Oct 25 2024 7:20am
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Looks good a very like the latest Pivi offerings. Doesn’t look like it would restriction much airflow and it might be good to get some cool air on the back of the device anyway.
Post #644906 Fri Oct 25 2024 8:01am
Purvesh
Re: Upgrading to either 12.3" or 13.3" screen
This is the 12.3" screen. In your pic it hangs quite low as as I've gone for the non CD AC unit the screen is larger to the top is slightly covered.
What's your audio output like I keep seeing that the screen uses different outputs depending on whether it's using the cars original interface versus Android etc
Also have you used the original GPS or the GPS that comes with it?
Post #644912 Sat Oct 26 2024 9:28am
Davenport
I really like the 12.3” integrated appearance it’s very trick but more costly with the new trim panel it requires from research I saw. Still tempted with the 13” jobbie. I’ve had an early Xmas present so able to purchase in the next few days. Last minute research is called for before placing an order. No idea I’m afraid at the moment on GPS or Audio.
I need to determine if I’ve got Bosch or harman, due to clock placement to the right believe it’s Bosch, if this isn’t correct someone please shout out before I commit!
Post #644914 Sat Oct 26 2024 2:41pm
Purvesh
I've sent you a PM that you'll find very useful mate!
Post #644915 Sat Oct 26 2024 4:21pm
Davenport
Falling at the 1st hurdle! Can’t even get the silver trim strips off either side of the centre console. The leading edge unclips but there’s no obvious direction it wants to go, a lot of resistance and nothing else is giving way. Used the dodo bars too don’t want to snap anything
Post #645109 Tue Nov 05 2024 6:27pm
Heremyjill
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Here you go
 "Every Day is a School Day"
Now 2014MY RRS SDV6 AB
Now 2018MY Ford Fiesta ST Line 140bhp
Gone 2006MY BMW X5 3.0d Le Mans
Gone 2001MY BMW 530d Estate
Post #645110 Tue Nov 05 2024 6:54pm
Davenport
Awesome 🤣that explains it I started with the L405 process ripping them off from the front no wonder there’s no give. I’ve watched that clip months ago and forgotten all the key content for sequencing. Back on the right path now 👍
Post #645111 Tue Nov 05 2024 8:09pm
Davenport
Right….straight into another stumbling block which should be a piece of cake. What’s the technique to tease off the 4 central coloured connectors? Fluked one off but after studying it can repeat the feat. From the YouTube clips the guys detach in seconds but I’m not having the same luck.
The blue was super easy with a tab, orange optical plugs giving me grief too.
And don’t have a connector at all in the white socket (top right corner), but the FFRR in the clip does, what’s it do?
Post #645115 Tue Nov 05 2024 11:07pm
Davenport
Right after a few trials and tribulations and significant assistance from a thoroughly good egg on here she’s in. What an absolute result it’s such a great upgrade transforms the interior removing the biggest tech weakness and moving it bang up to date.
Post #645226 Wed Nov 13 2024 11:08pm
Purvesh
Looks Fantastic great job Si!
Post #645227 Wed Nov 13 2024 11:11pm
Davenport
Cheers it’s early days learning to navigate android and all the functionality this thing brings. Screen resolution is absolutely ridiculous to the extent contemplating a reverse camera upgrade (in a separate post). Waiting in the car not a chore anymore with a myriad of apps to stream
Post #645228 Wed Nov 13 2024 11:18pm
aero
Australia 2012 Range Rover Sport 3.0 TDV6 HSE Java Black
yeah i put in the 13inch screen as well, everyone is wow by it,
because it looks like the new model setup,
i dont care for the pivi bs setup they put on, ive set mine up to be android with google play setup, basically a full pc with our premium surround setup which they want you to use their usb kit, but i use the Bluetooth and connect direct to our original unit, the kids love it.. when i dont need it swicth back to standard oem screen which also looks very good on the 13inch
Post #646237 Sat Jan 11 2025 10:36am
Purvesh
I've recently retro fit added 360 Cameras by a company in Bristol.
Absolutely amazing!
Post #646238 Sat Jan 11 2025 10:39am
