![]() | Home > Maintenance & Modifications > 3.0 TDV6/SDV6 oil cooler change |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 514 ![]() ![]() ![]() |
Been having a bit of oil come down the back of the valley onto the bell housing lately. Decided I’d replace the oil cooler and oil separator while doing an oil change and other maintenance.
a_a_t Member Since: 03 Sep 2019 Location: Bucharest Posts: 4 ![]() ![]() ![]() |
Hi! Planning to do a similar job on my Sport as well (2012 SDV6) and I've got a few questions for you, if you don't mind, please.
Original is Mann+Hummel. The Nissens is doing just fine with about 10,000km on it. Other than the updated bit you can’t tell them apart. I’ve installed a few Nissens oil coolers and haven’t seen any functional issues with them.
Thanks a lot!
I’d say that, too, changing oil pumps on a 3.0 diesel is a PITA.
I did it at 60K because of age... the car had almost 7 years at that point (first owner did only 50K km in about 6 years... so either the car was used on short trips or was used only occasionally).
That makes sense then.
Good to know that (hopefully) the glow plug job on the 3.0 might be a little easier |
H2OOW Member Since: 15 Dec 2020 Location: Ashburton, Devon Posts: 8 ![]() ![]() ![]() |
Hi
I still have the sample sitting here. Way too much going on and it slipped through the cracks. I’ll get it sent soon and report the findings. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Bit of a hectic time lately so just saw this. Directions are as looking at the front of the car.
