![]() | Home > In Car Electronics > l320 centre screen |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5133 ![]() ![]() ![]() |
You will need the 6CD headunit to drive it.
jpvd Member Since: 30 Sep 2023 Location: yorkshire Posts: 34 ![]() ![]() |
thanks andy - why do you need the 6cd head unit? - will the standard cd head unit not work? |
No. All the 4x4 data comes out the 6 cd head unit on optical fibre. |
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 322 ![]() ![]() ![]() |
L320 center screen is one of the most annoying things about the car. It’s really bright at night and needs turning off every time you drive it because it doesn’t remember its previous state. One of the best things I did to improve the usability of the car was unplug the thing. I did look at swapping it for a cubby, but it requires quite a lot of dash frame swap.
There is a light sensor below the revcounter (prefacelift models). This should make the screen automatically adjust its brightness |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9151 ![]() ![]() ![]() |
It is if you're driving off tarmac. ![]() 2008 TDV8 - it was a labour of love and is much missed |
well i have found a 6cd head unit and orange cable - just having difficulty finding the power wires for the screen - will have to look around some scrap yards
Arh the next issue.
cheers andy....well i think its just too much hassle and alot more complicated than just swapping....i was only interested in doing it so i could have the 4x4 info on the screen and the 6cd was just a bonus, but if it means adding amps, recoding, etc then its not worth the hassle...
Does it? I can see what traction control mode it’s in on the dash. The air suspension info never seemed much use. |
