Home > General (L461) > P550e poor headlight performance?
Lofc07182
Hi guys, just got my first Range Rover sport, p550e AB.
It has the digital LED headlights but on dipped beams, they seem extremely dim to the point where I have to double check if the lights are even on. Is this normal or am i doing something wrong?
Full beams are great.
Post #644584 Sun Oct 06 2024 9:46pm
Workpermit
Sounds strange. Can't say I've noticed mine to be bad and I came from a 2022 SQ7 with laserlights. 2024 RRS L461 P460e AB
Post #644585 Sun Oct 06 2024 10:11pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
My lights are excellent - worth checking they are on and not just drl’s
Post #644587 Sun Oct 06 2024 10:28pm
Zapp79
No problem with mine - you can definitely tell they're on! Absolutely superb headlights and the auto dimming/blanking function is brilliant.
If you're getting poor performance, have you noticed the "animations" when you start and shutdown the car? It should be pretty obvious if it's the DRLs or the headlights on.
Post #644609 Mon Oct 07 2024 10:36pm
Lofc07182
Thanks for the replies. Yes I notice the animation and also checked to make sure the lights are actually on. Think I need to test it again when it’s completely dark.
Post #644610 Mon Oct 07 2024 10:41pm
Lofc07182
Done a bit more driving and i think the issue is that when lots of cars in front, it blocks out so much of the beam that I’m losing too much light. I’ve noticed when no cars it’s much better even on dipped beams.
Had a couple of other questions which I’ll put here instead of starting a new thread.
- I use comfort mode most of the time but have tried dynamic as well, can’t really tell much difference. If I put it on auto terrain response, will this work ok if I’m not driving off road?
- From what I’ve read it seems hybrid mode only works properly if you use the stock nav which I never do. My battery still depletes on hybrid so it must be working to an extent? Is it simply that it works even better if you set a route on the stock nav?
Post #644688 Sun Oct 13 2024 1:20am
scrumps
Not meaning to be flippant, but have you checked the system is set up correctly in the vehicle settings?.
The Adaptive system depends on speed and the GPS location of the vehicle to adapt to the conditions.
Loads of info in the online manual/iguide.
https://www.ownerinfo.landrover.com/docume...1/G3342760
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #644707 Sun Oct 13 2024 7:15pm
Lofc07182
Hi, yes checked everything. I’m pretty good with tech and settings etc. I have the adaptive on so it’s definitely blocking out parts depending on traffic. As I said I think it’s simply down to the fact that when there are lots of cars it ends up blocking out so much of the beam, that it makes it seem very dim compared to normal. I don’t seem to have any issues with brightness when I’m driving on quite roads with no traffic.
Post #644708 Sun Oct 13 2024 7:24pm
