![]() | Home > Technical > 06 supercharged not starting |
| Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 358
I chased a similar fault on my v8 d3 same engine and fuel system.ptetty much. It had me going for a while very random it was to like you I was about to suspect the fuel pump.
| daxmatt Member Since: 16 Aug 2014 Location: kent Posts: 223 |
Thanks for reply, I'll check the cranking voltage tomorrow, Its almost like a lazy start, cranks and cranks ,kinda starts or does'nt if that makes sense. |
Quick update
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
If blue smoke it could be oil
I'll try the battery disconnect |
Is it normal for engine to stop when the oil cap is removed ?
Well, replaced the pcv valve, but turned out to be fuel contamination.The fuel station admitted liability, was also hundreds of posts on facebook concerning the said garage, regarding broken down cars.
| All times are GMT |
