![]() | Home > Technical > TDV8 - Restricted Performance but no codes |
| Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231
Well, I've just driven another 150 miles tonight and no further issues, bizarre ! 2010 RRS 3.6 TDV8 HSE Galway Green |
Sorry, I forgot to add that when the fault occurred, I noticed a trail of smoke from the exhausts, but it wasn't heavy smoke. 2010 RRS 3.6 TDV8 HSE Galway Green |
Just another update, I've tried a smoke leak test and there are no leaks. 2010 RRS 3.6 TDV8 HSE Galway Green |
| Boxers Member Since: 26 Sep 2019 Location: Lincolnshire Posts: 225
I get a similar thing on my TDV8 very occasionally, if I turn it off & restart it all is okay again, I've mentioned it to my indi who is excellent, and he could find no faults at all , I don't get restricted performance just a more throaty exhaust note and "engine fault" message, it has only happened once this year so far. Mine is a 2007 with 110,000 miles. |
Hi Boxers,
| Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 428
I have had the same issue for many years. It is a sticking variable vane actuator. The vehicle can go for months without issue then for periods of up to a week the restricted performance can reappear - restarting sometimes works in getting rid of the reduced performance issue but sometimes not. My car runs a cleaner exhaust in restricted performance mode. To fix the problem you will need to remove the turbos which means body off chassis - which is not going to happen any time soon - so I live with the occasional issue.
Thanks Melang, I also live with the Land Rover Quirk , even my independent describes it the same , it's good to hear I'm not the only one. |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477
plastic bag moving about in the bonnet air intakes I joke not. Always listen to old people or when they die you will live on in ignorance.
Bags on L320 ?
| Cpt Jack Sparrow Member Since: 07 Sep 2016 Location: Cardiff Posts: 182
^^^. This |
| RallyeSport Member Since: 19 Jun 2024 Location: Gloucester Posts: 113
Just a quick update.
| All times are GMT |
