Home > Technical > Identify this sound! (the front diff maybe?)
lemon
I just recorded this sound, is it the front diff perhaps? Usually begins around 30mph and maintains even in neutral. Continuous and you can hear the pitch change as I slow down to a stop. You may also hear my dad in the passenger seat swearing!
All hubs have been checked as I hoped it was one of those but I think the diff seems more likely now.
Post #643934 Tue Aug 27 2024 10:59am
lemon
I have discovered that as I turn to the right the sound disappears until I straighten up again. Turning left does not change the sound.
I changed out the front diff oil but the sound persists.
Post #643942 Wed Aug 28 2024 9:03am
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi sounds like a wheel bearing Thumbs Up
Post #643951 Wed Aug 28 2024 6:13pm
lemon
Thanks!
Sounds like it is coming from the front, if it stops as I turn right does that identify which one? I think it is nearside but not completely sure!
Post #643971 Fri Aug 30 2024 2:26pm
Iomegas
Hi yea would say nearside Thumbs Up
Post #643977 Fri Aug 30 2024 8:17pm
Iomegas
Hi did you get this sorted .
Post #644475 Sun Sep 29 2024 5:50pm
lemon
Sorry not logged on here a little while!
I changed out the fluid which had little to no effect. MOT came back clean except two advisories for the front two bearings!
So I'm trying to change those but having a nightmare getting the axle nuts off!
The fun never stops!
Post #645052 Sat Nov 02 2024 1:56pm
