Home > General (L494) > Engine Sound Petrol 3.0 SC v6
Ckl139
Hi. Looking at 2018 3l petrol.
See video in YT link below (hope allowed) specifically engine sound. Is it normal for these models?
https://youtube.com/shorts/xTVWSOHs0j8?si=RDqDw5UuMQeWJLWQ
Thanks
Post #643587 Mon Aug 05 2024 1:22pm
Farmer Chalk
We have the same engine in a 2018 F Pace with 37k. Yes from the front end on tickover it is very tappety but fantastic when you open it up.. it’s actually the same block as the 5 litre and SVR but using only six of the cylinders.. the other two are not machined out…
Post #643610 Mon Aug 05 2024 9:41pm
Ckl139
Thanks for confirming - that this is normal (i think?!).... yes tappety is right, its exactly that that made me question it?
Post #643622 Tue Aug 06 2024 12:40pm
Farmer Chalk
Yes it has been noted by others that the engine is not the quietest on tickover… however who cares when you get the silky howl when you open it up…
Really like the engine.. very smooth and linear.. the only fault I have read about this lump is on early cars there is a plastic water hose that fails and is subsequently replaced by a metal version.. haven’t looked at mine yet!
Good luck and enjoy it!
Post #643624 Tue Aug 06 2024 2:32pm
What? A V8 block but with a chunk of unmachined metal? Shocked 2012 SDV6 - it's missing a couple of cylinders
Post #643625 Tue Aug 06 2024 2:47pm
Farmer Chalk
Yup…they put a fancy counter balance in place of the two cylinders to keep the crank balanced.. the tops of the cylinders are cast over…
Who’d have thought it….
Post #643626 Tue Aug 06 2024 3:04pm
RedSnow
Canada 2013 Range Rover Sport Supercharged Baltic Blue
Not sure why that is making that ticking/tapping noise. I had a 2014 RRS HSE with the v6 petrol engine a few years back and it was quite. It never made any ticking or tapping noise 🤔
Post #643766 Fri Aug 16 2024 4:12am
That could be the supercharger coupler failing.
To confirm, remove the supercharger belt, and turn by hand. If there is play, you will need a new one.
One way to quieten down the engine is to use LiquiMoly oil, I had a ticking as well, LM oil solved that - not sure why, but a lot of the US owners swear by it. --
Post #643768 Fri Aug 16 2024 8:45am
See my thread on it: https://www.rrsport.co.uk/forum/topic62309.html --
Post #643769 Fri Aug 16 2024 8:47am
