![]() | Home > Maintenance & Modifications > Roof break light - remover? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5054 ![]() ![]() ![]() |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 338 ![]() ![]() ![]() |
Andy - When you say "sadly done from outside" are you referring to having to remove all the trim in the boot upper section before I can get to take off the spoiler? If so, dose the trim simple pull off i.e. held on with clips? Andrew Kennedy |
No trim removal required.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5081 ![]() ![]() ![]() |
Easy as.
Well. thanks both for your input re removing the parts for getting at the roof brake light - seems my car is not fitted out as a standard 2006 model?!?
rear cols procedure carefully.
The penny has dropped!! It doesn't help being dyslexic. I'll sort it tomorrow. Bastille Day hear in France Andrew Kennedy |
