Home > Technical > HELP Crankshaft sensor location ...2.7 l
Pistnbroke
Watched all the videos ..stripped off the heat shields in the turbo area but cannot find it or the wires leading to it .
Where do the wires come up at the top of the engine etc.
Any help appreciated. Always listen to old people or when they die you will live on in ignorance.
Post #643060 Fri Jul 05 2024 1:14pm
You need to get under the car I think
Its in an access panel behind the turbo
I gave you a link to a thread with videos and pictures. Lots of info in there so you can locate it,
Including a connector down below
Post #643063 Fri Jul 05 2024 1:55pm
Pistnbroke
In the prescribed areas in the video I can find nothing ..have it all stripped out below and on LHS ..if I could find a wire to follow it would help.
anybody been there done that ? Always listen to old people or when they die you will live on in ignorance.
Post #643064 Fri Jul 05 2024 2:05pm
There was a pic by cmb on D3 showing the 3 pin connector
Post #643067 Fri Jul 05 2024 6:46pm
Pistnbroke
Had a reply from No Expert in the US who tells me its behind the support plate ( 2.7l) for the turbo near the exhaust to turbo flange in fact the clip securing the connector is attached to that bracket.
I think the problem is that the layout of the turbo on the 3 litre is different ..furthur to the rear and on that model its accessible between the two sections of the turbo.
Took all those heat shields out for nothing !! Always listen to old people or when they die you will live on in ignorance.
Post #643079 Sat Jul 06 2024 7:06am
Do some research on Disco3 and the link I gave you.
It covers the 2.7 & 3.0 sensor change procedure differences
It’s been covered within the last year. Somewhere
Did you manage to see live value outputs for the cam and crank sensors? On diagnostic tool
Post #643081 Sat Jul 06 2024 8:07am
Oldandconfused
The 2.7 had one turbo, the 3.0 had twin turbo's with associated plumbing changes which may be yor problem.,
Post #643082 Sat Jul 06 2024 8:53am
