![]() | Home > General > ACE Fluid Change |
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477
There is a small filter ..some where under the rear in the valve block which can be replaced ..dont know if removing it will let it drain.
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167
Eh up pistnbroke
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156
Just removeing the filter will only drain about a teaspoon full.
Eh up Col
| Woody91 Member Since: 17 Feb 2024 Location: Norfolk Posts: 12
Following with interest, I've had the filter and fluid on my eBay watch list for a while now as it's one of those jobs I've been meaning to do. My plan was to change the filter then periodically change the contents of the reservoir for fresh fluid. |
| Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 359
I went to do my filter and fluid recently
| Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 428
I change my ACE fluid and filter every two years. After removing the valve block plug use an M6 thread screw to pull out the filter and put a new one in. Then use a syringe to empty the ACE reservoir and fill it with new fluid - start the vehicle and run it for a few minutes, then repeat the process about 5 times. I use Castrol Transmax Z ATF. I also use it for my power steering fluid which I change at the same time
Could you share which listing you used to buy the filter please. |
RVJ100010
Eh up Lrstaylor
If I understand the L/R w/shop manual correctly, the oil does not circulate the system until the engine is running and the vehicle is moving to open the valves and move steering etc. so just changing the oil in the reservoir it is not doing much really, if you do not move the vehicle and simply change the oil several times in the reservoir you are just changing the same oil again, which is why you need some way of opening the valves in the valve block, i.e. £500.00 L/R special tool |
Eh up Col
Those quantities are what is stated in the manual so assume they are about right, would have thought by now someone may have worked out a way of tricking the valves to open while stationary and use some sort of pressure bleeder tool. Hopefully someone may respond who has managed it, would be very useful I members I think
Eh up all,
| All times are GMT |
