Home > Maintenance & Modifications > Transmission Fault
zaphod
Transmission Fault
Can anyone suggest what this issue might be please? Every time I park up and turn off the ignition I get a 'Transmission Fault' message appear on the little screen on the dash. The car drives perfectly, no issues selecting gears, park or reverse and other than that message I wouldn't be aware of any issue.
I scanned for faults with my GAP tool and it came up with the code in the photo but the description just came up as 'unknown'. Thanks.
2005 RRS Sport S/C.
Post #642539 Mon Jun 10 2024 2:37pm
Heremyjill
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
I Have found this for you:
https://landroverforums.com/forum/lr3-28/t...844/page2/
It may give you a plan to resolve the issue "Every Day is a School Day"
Now 2014MY RRS SDV6 AB
Now 2018MY Ford Fiesta ST Line 140bhp
Gone 2006MY BMW X5 3.0d Le Mans
Gone 2001MY BMW 530d Estate
Post #642540 Mon Jun 10 2024 2:48pm
zaphod
That's a bit of a bizarre thing to do but hey if it helps fix it I'll try turning on my lights when I'm next in the car and see what happens, thanks! Laughing
Post #642541 Mon Jun 10 2024 3:19pm
zaphod
Well Censored me, when I put my headlights on the transmission fault doesn't appear! Never in a million years would I have thought would help but there you go!
Not sure where to go next but its a start...
Are the drive selector lights supposed to light up when the lights aren't on? Can't remember now. Thought that might have been the issue but if they aren't supposed to come on in daylight then that's nothing useful...
Post #642546 Mon Jun 10 2024 5:30pm
Disco_Mikey
https://www.disco3.co.uk/forum/good-luck-f...ight=P081c
Front of NS sill, inside the car Thumbs Up
Post #642548 Mon Jun 10 2024 7:01pm
zaphod
That looks kind of scary and pretty involved - will have to be a sunny weekend job!
Thanks for the links guys Thumbs Up
Post #642559 Tue Jun 11 2024 9:42am
thegolffather
United States 2013 Range Rover Sport 4.4 V8 HSE Lux Siberian Silver
I also have a transmission fault waring but it comes and goes same as my suspension fault message. The car drives fine Idea
Post #644026 Tue Sep 03 2024 6:34am
pelle
Sweden
I have transmission fault on and was finding this thread today.
I was just in my RRS S/C 2005 and tried the lamp switch on trick defore starting the engine.
It works šŸ˜…. I could even select M/S mode and use the manual shifter.
I noticed one thing, when parking and switching lights off before turning ignition off I couldn’t
take out the key from ignition switch!?
Then I started the engine again with the light switch on and kept it on until I had shutdown the engine.
This time I could take out the key.
Could it be connected with this transmission snag?
Post #644190 Wed Sep 11 2024 4:09pm
Yeap.
If it thinks the gearbox isn’t in Park, it won’t let you remove key.
You need to resolder a red wire splice in sill somewhere.
Post #644192 Wed Sep 11 2024 4:16pm
pelle
Sweden
In the US-forum someone referred to green/pink wires and you say red wire?
Are there different on RRS than other models? Do you know?
Post #644206 Thu Sep 12 2024 11:43am
Well if you can find splices for both colours, it’s probably worth doing both while you are at it !
Post #644207 Thu Sep 12 2024 12:02pm
pelle
Sweden
You are right.
I have been there doing grey wires for left front door window stopped working.
Post #644208 Thu Sep 12 2024 12:12pm
thegolffather
What is the lamp switch on trick? on mine the error does not come on until I select drive 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5
Post #644222 Fri Sep 13 2024 2:08am
pelle
Sweden
If you switch the headlights on before starting the engine you will not have the
ā€œtransmission faultā€ warning when selecting D with the gear shifter. šŸ‘
If you read the links to other forums earlier in this thread you will be enlightened.
Post #644224 Fri Sep 13 2024 9:45am
thegolffather
Thank you 1973 Clubman GT * 2013 MB C250 * 2013 BMW X1 * 2013 RRS HSE Luxury * 2016 Mazda MX5
Post #644256 Mon Sep 16 2024 1:11am
