![]() | Home > General > Smoke test / pressure zero |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 355 ![]() ![]() ![]() |
You won't build up pressure in the engine. What smoke tester are you using??
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 464 ![]() ![]() ![]() |
how to do smoke test is here..
Toonraider Member Since: 15 May 2022 Location: Newcastle upon Tyne Posts: 117 ![]() ![]() ![]() |
This one. |
mispost Always listen to old people or when they die you will live on in ignorance.
Been away a while, but forgot to ad that smoke does emit from the elbow of the intake pipe that leads down to the turbo. There's a rubber grommet or gasket on the end. I've tried searching for the part number, but no luck. Anyone know the part I mean by chance ? |
peterjj Member Since: 15 Mar 2017 Location: Canberra Posts: 49 ![]() ![]() |
should find the part number here somewhere https://parts.jaguarlandroverclassic.com/p...and-rover/ Pete
Hi, thanks for that but I'd looked at that one and it didn't show. It's a rubber seal that sits in between the two pipes to the right on the picture near h2 bolt. Approx 80mm round and 50mm deep with ridges to help keep it in place. Strange that it's not listed. |
