Home > Maintenance & Modifications > Suspension Fluid in France
mab25715
Hello
Bit of a long shot but I'm in rural France on holiday and I need to top up the tank for my suspension. I have a 2011 RRS 3.0 HSE can anyone help with what can be used as I am unable to get to a Land Rover garage, can power steering fluid be used until I get home?
Thanks in advance
Post #642129 Tue May 21 2024 5:08pm
Could see if you can find some Ravenol SSF or Texaco cold climate p/s oil or equivalent, Personally I don't think I would top it up with anything like Dextron III p/s oil.
Post #642137 Tue May 21 2024 11:12pm
mab25715
I am unable to get hold of anything like that here, I'm hoping someone knows of a simpler alternative until I get back to the UK
Post #642141 Wed May 22 2024 9:16am
JonnyCJ
Can Amazon not deliver it to you ?
Post #642142 Wed May 22 2024 9:26am
mab25715
Yes but not until 31st may
Post #642145 Wed May 22 2024 9:44am
mab25715
Can I use power steering fluid?
Post #642158 Wed May 22 2024 3:23pm
jimbg
Have you done a Google advanced search and selected France as the country for results? 2026 P460e Autobiography on order
2022 HSE Dynamic P400e
2006 HSE
Post #642159 Wed May 22 2024 3:53pm
mab25715
Yes I have tried every avenue
Post #642169 Thu May 23 2024 8:27am
83series3
United Kingdom 2007 Range Rover Sport TDV6 HSE Zermatt Silver
is an alternative to pull one of the wiring clips from the valve block, to force an error and stop the dynamic response from operating? A long shot, but maybe worth a try ....
... is the reservoir empty / any ideas why its run low?
Post #642218 Sat May 25 2024 9:42pm
I think the problem is even if you disable the system from working by disconnecting the wires, the pump will still be running, so depending on how much oil has been lost it could still damage the pump if run dry or starved of oil.
Post #642221 Sat May 25 2024 10:37pm
