![]() | Home > Maintenance & Modifications > EU Headlight conformity |
JDPRRSUK Member Since: 13 Apr 2023 Location: Leeds Posts: 305 ![]() ![]() ![]() |
Oh the joys of French bureaucracy!! You might need to by French/Euro headlights rather than just change setting. They are different as link pattern is on other side. |
France2024 Member Since: 14 May 2024 Location: Creuse Posts: 3 ![]() ![]() ![]() |
I've been advised by a few parts specialists that the lights are the same part numbers in EU and UK. So even if I purchase in France I would just be replacing like for like. Argh!!!! I just don't know what/who to believe. Might have to take it to the nearest dealer for an 'attestation' to say they are fine and see if that's good enough. |
Good luck - been through your pain albeit a different brand. A Cert of Conformity from JLR along with CT should be enough… |
Should be - but isn't |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9109 ![]() ![]() ![]() |
Presumably there's an appeal process for such cases? Take it over the technician's head and present the manufacturer's certificate of conformity, etc., to the next level. 2012 SDV6 - it's missing a couple of cylinders
This page suggests there are different parts for RHD and LHD units: https://www.advancedfactors.co.uk/headlamp...2707-c.asp 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 462 ![]() ![]() ![]() |
You need to dismantle the lamp and remove the bit of metal on the shutter that is causing the kink. Maybe the moving bit is not moving out he way enough.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5114 ![]() ![]() ![]() |
2008/09 headlights will not fit a 2013 vehicle, the headlights on my 2013 specifically say UK Spec. on them although according to the handbook there is no adjustment required to drive abroad with them due to the design of the beam, as suggested there are different part numbers listed for L/H/D vehicles so to me personally that would suggest you need the L/H/D units to conform correctly. As your car is a 2013 I would hazard a guess your vin no. starts DA, assuming they are the adaptive ones you probably need LR030761 and LR030757. I certainly wouldn't try and bodge your original units up as there no guarantee they would be acceptable and would probably just make them useless and of no value, where as at the moment you could probably sell them to offset some of the cost of replacements.
Get 10/11 EU spec headlights, they will be correct and put out more light than the 12/13 headlights.
Depens how fussie the OP is, as they will not be quite the same as the MY10/11 headlights and rear lights will have grey internal backing the 12/13 has black.
Legal and imported over stylish and left behind? I'd take the former. 2012 SDV6 - it's missing a couple of cylinders
Nothing to do with stylish or left behind really. It's simple the OP need to change his headlamps to one's which conform to the EU spec. not the UK spec. If they wish to keep the aesthetics of the car the same they need to use the one's from a MY12/13 vehicle, if they are not bothered then they can use them from any MY10 to MY13 vehicle, however I would imagine they would have to be a matching pair, not one from a MY10 and one from a MY13 if as No Expert said they give out a different light intensity/beam of some sort.
10/11 have the internal lever to flatten the beam pattern for driving on the other side of the road. The pattern is different and throws more light at the shoulder/road signs.
