![]() | Home > General > Fitting Brembos to my 3.6 TDV8 |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9130 ![]() ![]() ![]() |
Doesn't your TDV8 not already have 4-pot Brembos? I thought they were standard fit on the TDV8. Mine certainly had them. 2012 SDV6 - it's missing a couple of cylinders
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 433 ![]() ![]() |
Nope - some rusty looking crappy things. Mind you it had new pads and discs not long before I bought it, so typically rubbish timing to do the switch. |
Pre facelift TDV8 had 4 pot Brembos
Thanks Mikey - how does that affect mounting ? Are carriers needed for fitting the 4 pots on a MY 10 ?
If they are 6 pots you will need new discs/pads as well as the discs are 380mm diam. the 4 pot used 360mm diam. which is what your car will have as standard, the original backplates should be o.k. though. The brembo's will bolt straight on to the knuckle/hub assy. without any carriers, you could use the original carrier bolts for mounting the brembo's as they are the same, they are also however torqued up to something like 275Nm. personally I prefer to use new bolts.
Perfect - thanks Col. I’d need new pads anyway with the Brembos, even if they are 4 pot ? |
![]() 2008 TDV8 - it was a labour of love and is much missed |
So in theory a 2009 TDV8 with Brembos will have 6 pots ? |
No 3.6 TDV8 came with 6 pot Brembos from the factory |
Great - thanks for clarifying. So it looks like I’ll be getting 4 pots and they’ll work with my existing 360mm discs and existing D4 pads, both of which have approx 1,000 miles on them. |
Almost. Pads for Brembo calipers are different to D4 |
Ah - thought they would be, but couldn’t find anything online that showed a different pad depending on the caliper. |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 499 ![]() ![]() ![]() |
I refurbed some four piston Brembos for my 2011 L320 3.0. They’re a direct swap, just remove the old calipers, pads, sensor and carriers then bolt up the Brembos and drop in new pads (P44018) and new wear sensor (A00265 is the sensor for 2010-2013 6 piston Brembos). Easy job.
