![]() | Home > General (L494) > P400e EV range/charging |
SpiderPig Member Since: 13 Mar 2024 Location: Herefordshire Posts: 144 ![]() ![]() |
Mine usually ends up with 29 or 31 miles. I’ve had mine a few months now but never seen it stuck in the low 20s. I’m also using a three-pin plug.
midlife Member Since: 24 Apr 2022 Location: Cork Posts: 7 ![]() ![]() |
It's more a guess meter, it works on previous drives I believe and gives an approximation more loads, sprited driving,heated seats windscreen etc will drop the range |
If this is correct, I’ve clearly not thrashed my car enough. I’ve never seen my full capacity go under 29 miles. 2021 P400e Autobiography |
Vanstmic Member Since: 05 Nov 2023 Location: South East Posts: 18 ![]() ![]() |
Thanks for the replies.
If you’ve gone through a main dealer, I’d ask them to check this out for you. My 70 plate consistently gives me 29 or 31 miles for a full charge. This is charging via a JLR three pin cable with the car on the driveway.
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1921 ![]() ![]() |
If charging is complete, i.e. 100% then your charger is fine. The range is nothing to do with charging assuming it is at 100% The range predicted is just the same as an pure ICE car, a guess based on previous usage. I get high twenties predicted as I am running EV mode on local journeys and do not exceed 40 mph. What sort of trips are you making in EV mode and what sort of speeds? 2026 P460e Autobiography on order 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
m13lky Member Since: 08 Aug 2016 Location: Scotland Posts: 311 ![]() ![]() |
Mine showed 28 miles this morning, as you say even when mine was new in 2021, around 30 miles warm weather then down to 21 in the coldest period, every time my charges up to 100%, if I was you I’d get your supplying dealer to check the batteries as at this time of year I’d expect it to be more than 21 miles most times it was charged. JLR guarantee they will still be 75-80% efficient at 8 years old but this will have multiple conditions around it so they don’t need to pay out for replacements. |
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 391 ![]() ![]() |
How many times are you charging the car per tank of fuel? Tim RRS sold and replaced with a Skoda Kodiaq after appalling RR Dealer experience and LR inability to supply new cars in any sort of reasonable time frame.. |
So far I am using EV only, local journeys at low speed, using about 50% of the battery and then charging back up to 100% within 4 hours every other night. I haven’t put any fuel in since the I got it 2 weeks ago |
Well it's using that short journey to predict the range. 2026 P460e Autobiography on order
I charge nightly to full charge. My trips vary from 70-80 miles in a day to sometimes short trips of 2-3 miles.
Mine does multiple daily short journeys, as I said this time of year it normally shows around 26/28 miles, up to 33 in July and down to 21 in winter, over the last 3 years. Only seems to change depending on temperature from what I can see. |
I guess I’ve been lucky then 2021 P400e Autobiography |
Spoke to the dealer. Apparently the range estimate is based on the last 40 miles driven. It is relatively hilly where I am I guess but still doesn’t make sense to me. It’s not like I’ve had the aircon/seats on the whole time which they also said was a factor. Will give it longer to see if it changes when my drives start to vary a bit |
