Home > General (L461) > Ghost 2 Pro vs Starline i96 immobiliser MY2024
skilachi
Anyone fitted a Starline i96 immobiliser on the Range Rover? Looking at the Starline i96 as it's got a call alert on your phone if someone tries to steal the car.
Post #641451 Wed Apr 24 2024 2:24pm
scrumps
I’ve got the Ghost-2 fitted in my 24MY D300 AB.
It’s configured on the gearbox so anyone trying to select a gear with it enabled kills the engine dead, but I can still use remote start via the App.
Guardian mode on Secure Tracker Pro will tell me if there is an attempt to tamper with the car.
With both in action - I’m covered.
Ghost fitted in a couple of hours in my drive and it’s been faultless.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #641497 Thu Apr 25 2024 6:24pm
skilachi
Hi @scrumps, thanks for the info.
Did you get the Ghost 2 Pro or the Basic Ghost 2?
Believe the added advantage of a Starline models (i96/Halo+) is they can be configured alongside your mobile phone you can get a phone call alert and easy to disable when putting it in service mode via the app.
Also with the Starline Halo+, the horn will honk out loud if they tried to start the car (might be annoying for the neighbours) but I think the feature is actually very good and only way to disable the alarm is using the Pin sequence.
Thing about Guardian Mode, when it is turned on, you can use any other features on the InControl Remote App.
Post #641513 Fri Apr 26 2024 10:21am
scrumps
Just the standard GHOST-2.
I mainly use it with the App which means I don’t have to use the PIN code. You can pairvtwo phones.
Changing the PIN is easy and putting it into Service Mode is just five operations of a certain switch. Takes seconds.
Not sure what features of the app you may want to use if the car is in Guardian Mode, but it’s never affected anything I wanted to do.
I used www.trackershop-uk.co.uk for my fit at home. The guy normally covers south west London but was heading home to Wales for a break and did me on the way. Only took a couple of hours and it was a really neat job.
Post #641541 Sat Apr 27 2024 8:21am
skilachi
Sorry, i meant when you turn on Guardian mode, all remote features are disabled. I also like the idea of pairing with the phone so i don't have to use PIN code.
Thanks, i will have a look on the website but think i'm leaning towards the Starline with the (gear selection cut out, call alert + horn honking)
Post #641567 Sat Apr 27 2024 8:38pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
You might want to check what the dealer says about affect on warranty. I was told could affect SOTA and warranty if any electrical issues cropped up.
Post #641568 Sat Apr 27 2024 11:34pm
skilachi
Went for the Ghost 2 with ADR tags and the call alert feature . It is fitted to cut off the engine when the gear is selected without the Pin code sequence entered and will get a phone call alert to notify me as well.
The walk away locking is still not working even when I'm like 50meters away from the car for over 5-10mins. Do i have to enable keyless entry for this to work? I have re-enabled the option in the menu.
Post #641735 Mon May 06 2024 7:55am
scrumps
Sorry but to my mind, ADR tags are a retrograde step.
If your keys get pinched, your car is gone.
If my keys get pinched, they need to know my PIN or nick my iPhone (from the side of my bed), crack my iPhone then enable the App to have my car away.
Phone Alert - covered by Incontrol Secure Tracker Pro!
My 10p.
Post #641751 Mon May 06 2024 1:32pm
skilachi
@scrumps decided not to use the Tags anymore and kept them away from the keys....infact 10metres away from the house . Only using the Ghost app on the phone or at times the Pin sequence.
Post #642425 Wed Jun 05 2024 11:16am
Sandancer69
United Kingdom 2013 Range Rover Sport SDV6 SE Orkney Grey
Had a Ghost fitted last week on my 2025 P460e Edition. So far, completely faultless and gives me extra peace of mind. Although I also have a Tracker and Disklok.
Post #648686 Thu Jul 03 2025 4:06pm
41jules1967
I have a ghost installed on both my RR Sport and Disco Sport.
I admit I do have the tags as the code entry was a bit hit and miss on the discovery, so I have to make sure there's no chance the keys can be pinched but I guess you could simply put the tag in your wallet or phone case so they're kept separate if you're bothered.
Haven't renewed the tracker as the thieves know where the boxes are and simply disable them.
Instead, I bought one of these
https://www.powerfuluk.com/collections/l49...centre-cap
Popped an apple air tag in it should be virtually undetectable for no running costs. Seems to woerk really well. Tested the apple find-my app when the Mrs has been out in it and it's reported back exactly where she is.
Plus the car still reports its location in the app, even without the tracker. 2021 L494 D300MHEV Autobiography
2019 Discovery Sport D180 HSE
Post #648688 Thu Jul 03 2025 5:18pm
