| RRSPORT.CO.UK | ||
|  | Home > General > Power Steering Fluid Change |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | I recently started option 1. I extracted fluid from the reservoir, filled with new, started the car and turned the steering wheel lock to lock a few times. Shut off the car, and repeated the aforementioned about eight times. I got about three reservoir refills per liter. My fluid was black when I started, it’s now moved to a transparent brown. Figure I’ll repeat the same process when I do the rear wheel bearing that’s starting to sing me the song of its people.
|  Tue Apr 16 2024 5:29am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Just do option 2. Disconnect a pipe low down.
|  Tue Apr 16 2024 6:00am |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up
|  Tue Apr 16 2024 7:19pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      |
|  Tue Apr 16 2024 8:14pm |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up Col
|  Tue Apr 16 2024 8:45pm |
| TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 167      | Eh up all,
|  Wed Apr 17 2024 8:17pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | Haven't got around to it yet, but have a spare reservoir cap here which I was going to fit to a 5 liter container to, then fit that in place of the existing cap temporarily to in effect make a 5l reservoir to fill with fluid, then remove return hose and feed it into a container, blank the reservoir return and bleed as per w/shop manual, hopefully be able to change fluid all in one go without the reservoir running dry. Not sure if it will work or not, only one way to find out I guess.
|  Thu Apr 18 2024 4:40am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | TTR. I would just keep it simple. Let gravity do its thing.
|  Thu Apr 18 2024 7:50am |
|  Thu Apr 18 2024 6:55pm |
|  Sat Apr 20 2024 6:16pm |
| Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5156      | The small straight outlet on the bottom of the reservoir is the return, the larger angled one is the suction feed supply to the pump.
|  Sat Apr 20 2024 9:40pm |
| T Member Since: 18 Feb 2024 Location: Isle of Wight Posts: 106      | This bloke's method seemed to do the trick OK:
|  Sun Apr 21 2024 8:12am |
|  Sun Apr 21 2024 3:52pm |
| NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 522      | The first few pulls on mine were also a nasty black, almost used diesel oil black.
|  Sun Apr 21 2024 5:16pm |
| Posting Rules
