Home > Technical > Park break release
Use the handbrake every day, just don't leave it on for over a year and expect it not to seize up. It's the latter aspect that's the problem here. 2012 SDV6 - it's missing a couple of cylinders
Post #641181 Mon Apr 15 2024 9:20am
karlos01
thaing was it wasn't even on for a year I only use the the hand brake if parked on a slight incline
it just general rust as you say it been parked for a year
Post #641197 Tue Apr 16 2024 6:11am
If you don't use something mechanical other than very occasionally then it's no great surprise that it can seize when used. Best advice with the EPB is to use it every time - use it or lose it, basically. Thumbs Up
Of course, over time the EPB wears and can eventually cause an issue - especially if not correctly checked, cleaned and adjusted at each service. 2012 SDV6 - it's missing a couple of cylinders
Post #641205 Tue Apr 16 2024 9:37am
For some stange reason I have got into the habit of using the park brake every time when out and about, but when the car is parked in the garage I never apply it, I do however clean out the drums etc. and check/adjust it every service, proably tempting fate now but never had a issue yet. Laughing
Post #641206 Tue Apr 16 2024 9:59am
karlos01
had the old girl back from mot all it failed on was front ball joint rubber split
I can go with that for being of road for a year
I do agree with you all the EPB does need using and maintaining
Post #641317 Sat Apr 20 2024 9:23am
karlos01
finally got to bottom of my park brake problems has a sticking cable the dust cover was split and cable had rusted so wasn't releasing the shoes enough
garage took it off and lubed up the cable replaced the cover now all working as it should
Post #641975 Wed May 15 2024 8:51pm
