![]() | Home > General (L494) > Towing Software? |
PhilMid Member Since: 14 Aug 2015 Location: Hull, East Yorkshire Posts: 61 ![]() ![]() ![]() |
If you tap the screen you should have icons which turn on the tow hitch assist line and the car parking asssist lines |
SpiderPig Member Since: 13 Mar 2024 Location: Herefordshire Posts: 144 ![]() ![]() |
I'm pretty sure that the trailer tow assist is an optional extra. Whether this can be retro-fitted is something I have no idea about. 2021 P400e Autobiography |
Tow assist and the lines to help hitch up are different things. The OP was asking about the line to assist the hitching of a trailer/caravan, not tow assists that aids when towing. |
RRS? Member Since: 02 Sep 2023 Location: Lincs Posts: 36 ![]() ![]() |
Thanks for the help and suggestions, I don’t have an option on my camera for the hitch line though?
Russtyp Member Since: 13 May 2022 Location: Caerphilly Posts: 22 ![]() ![]() |
The GapIID can enable this function |
Perfect, do you know where I need to be looking? 2004 D3 HSE TDV6
You need to contact Pat at Gap and ask for access to the unconfirmed list.
Notyalc Member Since: 01 Aug 2022 Location: Northumberland Posts: 46 ![]() ![]() |
You should get a RED dot which is where the ball is.
I agree you do get a red dot showing where the tow ball should be.
I get spot on under the hitch every time.
