| RRSPORT.CO.UK | ||
|  | Home > General > RRS 4.2 S/C front driver side is leaning lower |
| wiztaz Member Since: 28 Dec 2021 Location: Essex Posts: 41    | Hope everyone is having a lovely Easter break!
|  Mon Apr 01 2024 7:57am |
| JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 435    | Hmm - one corner would have meant a leak on that corner airbag or valve connection. All 4 dropping sound like the tank isn’t holding pressure or a compressor fault.
|  Mon Apr 01 2024 9:25am |
| wiztaz Member Since: 28 Dec 2021 Location: Essex Posts: 41    | Yes i definitely removed brown 5 top row second from right
|  Mon Apr 01 2024 11:25am |
 Any updates? | ||
|  Wed Apr 03 2024 6:30pm |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | It should be a yellow 20a fuse you are removing overnight. | ||
|  Fri Apr 05 2024 10:15am |
 Would you mind circling the one I need to remove?   | ||
|  Fri Apr 05 2024 11:34am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | Fuse 26
|  Fri Apr 05 2024 12:20pm |
| wiztaz Member Since: 28 Dec 2021 Location: Essex Posts: 41    | Thank you so much Andy:) I will try that over the weekend and report back. | ||
|  Fri Apr 05 2024 1:08pm |
 Tried this over night and the car pretty much held its height. Front dropped by only 1cm in the arches but back stayed exactly the same. Front D - 19cm / 17.5cm Front P - 17cm / 16cm Back D - 18.5cm / 18.5cm Back P - 19.5cm / 19.5cm As soon as i put the fuse back in it dropped to normal height as below Front D - 14cm Front P - 14cm Back D - 15cm Back P - 17cm last few days i've noticed that even if I leave the car parked for 1hr its dropping and when I start it again the car starts leveling itself. Front drivers side suspension strut has already been changed. I will get front passenger side changed this weekend so they are in pairs. Any ideas? | ||||
|  Thu Apr 11 2024 6:19am |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5145      | If you haven’t already, clean the front valve block and change the seals.
|  Thu Apr 11 2024 7:21am |
| Posting Rules
