![]() | Home > General (L494) > brake sensor reset |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 517 ![]() ![]() ![]() |
Should go away once replaced. The connectors are fully seated? Brake fluid topped up? 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Tanner Member Since: 29 May 2023 Location: Staffs Posts: 10 ![]() ![]() |
Yep plugs fully seated fluid topped up after rear caliper needed replacing as it had seized and would push back in |
Does it go away if you unplug the sensors and short the car side connectors? Check each plug individually, may have a dud sensor. If that doesn’t work then you need to start chasing the wiring. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Cheers for that,it's exactly what I did ended up changing the rear sensor and all good again thanks for thd help |
