Home > General > Wing mirror memory
wiztaz
Wing mirror memory
Hi Guys,
My right side powerfold mirror sometimes holds memory position but other times not. If I’m reversing for example it dips but then returns to a non memory position. It’s a 2007 RRS. Any ideas?
Thanks
Post #640948 Fri Apr 05 2024 10:38am
Known problem I think.
Ie over time after several reverses the get out of position
Post #640949 Fri Apr 05 2024 10:44am
wiztaz
So no fix for it?
Post #640955 Fri Apr 05 2024 11:17am
Not that I know of.
I switched off the function and manually move it down.
If you think one side is worse, you could try changing the motor assembly
Post #640956 Fri Apr 05 2024 11:26am
wiztaz
The left side works without any issues. It’s just the right side.
Is the motor assembly inside the wing mirror unit or the door card?
Post #640961 Fri Apr 05 2024 12:32pm
Fits behind the mirror glass.
Like this.
https://www.ebay.co.uk/itm/266512402349?mk...media=COPY
8 pin connector for memory function
Post #640964 Fri Apr 05 2024 1:17pm
wiztaz
Thank you Andy. I’ll take a look at that 👍🏼
Post #640994 Sat Apr 06 2024 9:06am
