![]() | Home > Technical > Broken crank |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1195 ![]() ![]() ![]() |
ouch, sorry to hear that mate |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5045 ![]() ![]() ![]() |
It it’s a 3.0 oval autos. |
pjdow Member Since: 01 Dec 2021 Location: Sheffield Posts: 5 ![]() ![]() |
2015/16
if your services were at a Land Rover dealer, you should approach them for a claim --
Sadly the last 3 years are local specialists, but logged on the landrover service portal. |
I think you still have a chance here: take it to the last LR dealer you used and request a goodwill claim. --
Crs Member Since: 04 Sep 2022 Location: Hampshire Posts: 82 ![]() ![]() ![]() |
Sorry to hear this , you must be devastated, how landrover ever got away with this catastrophic failure I will never understand, as said see if you can get something out of them but I wouldn’t hold your breath on it. Land Rover should have been taken to court over this.
To put this one to bed
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 139 ![]() ![]() |
Does this ever happen to Ford, Jaguar and Citroen? |
Yes, but the volumes sold, particularly with Citreon and Peugeot make is less visible. |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 432 ![]() ![]() |
Following on a bit - from what I’ve gleaned from speaking to those in the know, a snapped crank can result in a warped engine case. This then makes the case junk, but apparently it’s the rods that are the problem, as you can’t get them, so to rebuild an engine, you need to cannibalise good rods from another broken engine. |
feel very sorry for this chap, first time I hear of this in an F-Pace: https://www.4x4community.co.za/forum/showt...ost5259042
-- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
